Warning message
pkhatri Fri, 03/17/2006 - 16:31
  • Purple, 4500 points or more
You can terminate PPTP tunnels from hosts using PPTP with MPPEbut I'm don't believe you can configure a PPTP tunnel between two Cisco devices.
You might want to look at the following doc though:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t5/dt_pptp.htm
Hope that helps - pls rate the post if it does.
Paresh
