H323 gateway - G711 to PSTN?
Answered Question
Mar 13th, 2006
All,
I have a single region for all of my devices using G711. How do I force all calls going out to the PSTN to use G711? It seems that all calls to the PSTN are using G729. I can manipulate it inbound using the "codec" command under the voip dialpeers, but how do you do it outbound?
Thanks in advance.
Correct Answer by thisisshanky about 11 years 5 months ago
If the gateway has the same device pool with the same region configured, then it should use g711.
Overall Rating: 5 (1 ratings)
Correct Answer
thisisshanky Mon, 03/13/2006 - 16:06
  • Purple, 4500 points or more
jblalock1337 Mon, 03/13/2006 - 20:12
Thanks, that's what I thought. I found an errant dial-peer used for a gatekeeper that was changing my codecs :O
