Warning message
Mapping ports to MAC addresses on PIX
Mar 13th, 2006
Greetings,
I've been trying to look for anything relating to this over the Internet, but could not find anything.
Is it possible to map MAC addresses to certain ports/interfaces on a PIX, if so, can someone please point me to the right direction?
Thank you,
Lee
aashish.c Mon, 03/13/2006 - 21:39
  • Bronze, 100 points or more
AFAIK there is no method by which you can bind a mac address to ports/interfaces. Kindly update me about your specific requirement, so I could try to find a workaround.
regards
aashish C
lalcantara Mon, 03/13/2006 - 23:21
My other option was to lock down MAC addresses on the switch level. I was just curious if it was possible to do it on the PIX.
Thank you,
Lee
aashish.c Tue, 03/14/2006 - 01:16
Ohh yes, switch would do this for you. PIX wont do it.
regards
aashish C
