PIX config not getting archived in CiscoWorks after upgrading to ver 7.0
Mar 13th, 2006
My pix device config is not getting archived in CiscoWorks RME after upgradation of device from version 6.3 to 7.0.
Prior to upgrade the device config was getting archived properly.
My CW version details are given below.
CiscoWorks Common Services with SP2
Resource Manager Essentials 3.5
Resource Manager Essentials Incremental Device Support 3.5
RME3_5_IDU -13_0 Resource Manager Essentials 3.5 Incremental Device Update 13.0 (latest version)
Configuration Archive 3.5
Configuration Archive Device Support for the PIX Firewall 1.4
Do I have to install some new package/patch for the PIX config to get archived ?
Vijay
nhabib Tue, 03/14/2006 - 05:27
  • Red, 2250 points or more
This looks like CSCsb89594:
RME does not work for PIX with multi context feature enabled
Unfortunately there doesn't seem to be fix for it.
vijay_sequeira Tue, 03/14/2006 - 07:04
Thanks for your reply
Currently the pix has the following features licensed.
Licensed features for this platform:
Maximum Physical Interfaces : 10
Maximum VLANs : 100
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has an Unrestricted (UR) license.
However when I check the mode status I get the following output.
fw# sh mode
Security context mode: single
The multicontext feature is not being used so will the CSCsb89594 bug apply to this situation.
Vijay Sequeira
