Warning message
Speed problems with an ATA 186
Mar 14th, 2006
We need an Ata for servicing a machine remote. The connection is thru the ISDN to a 2821 to the ATA and then to the Modem. The speed is only 2400 bits. How can I speed up the ATA to 56k?
Thanks for helping!
beth-martin Mon, 03/20/2006 - 07:21
  • Bronze, 100 points or more
Officialy modems are not supported on the ATA. I think nothing much can be done on this aspect and you need to check for other alternatives.
gsobeski Fri, 03/24/2006 - 06:56
we've been able to dial thru ATA's but you'll have to crank your baud rate down to like 38400 on the calling machine in order for it to work. I think you can pretty much rule out 56k.
holzwaku Mon, 11/20/2006 - 09:57
Could you kindly let me know the config in the ATA and your IOS gateway that allowed the ATA's to work as a modem? We cannot get it to work no matter what we try. We're thinking of going with Linksys Sip instead to get this to work. Thanks for any help you can provide.
