Warning message
basic failover question
Mar 15th, 2006
hello,
my question is the following, I have a cisco 2600 router connected to a T1 line and a 30 Mbps cablemodem line, I want the cablemodem as my primary connection and the T1 as my backup connection, when the cablemodem goes down, I want the T1 up and running.
I did this with priorities y the ip route command, BUT when I restart the router, the priorities changes, and when the cablemodem goes down and the T1 goes up I have to configure NAT manually. Im a begginner, so I need your help!!
here is my running config
pkhatri Wed, 03/15/2006 - 05:12
  • Purple, 4500 points or more
Try the following changes:
no ip nat inside source list 1 pool cablemodem overload
ip nat inside source route-map CABLEMAP pool cablemodem overload
ip nat inside source route-map T1MAP pool t1 overload
route-map CABLEMAP permit 10
match ip address 1
match interface
route-map T1MAP permit 10
match ip address 1
match interface
Hope that helps - pls rate the post if it does.
Paresh
comechivos Wed, 03/15/2006 - 08:26
thank you so much.
should I leave the ip route Priorities????and if I 've to leave them, how can I do to make them static? because they change when I reboot the router.
thanks
pkhatri Wed, 03/15/2006 - 17:15
I presume you mean the Administrative Distance when you say priority. I would suggest that you remove it from the primary route and leave it on the secondary route so that it becomes a floating static route.
Paresh
comechivos Wed, 03/15/2006 - 18:19
the problem with that is..... when I remove the administrative distance, appear automatically again with a 254 value, and if I leave it, it changes to 254 too. so, do you know how to make it static?
pkhatri Wed, 03/15/2006 - 18:26
Enter in the following:
no ip route 0.0.0.0 0.0.0.0 64.84.44.1 240
copy run to start
Then, do a 'show run' to see what you get.
Paresh
comechivos Thu, 03/16/2006 - 03:46
I did that already, and when I remove it, appears again automatically with a 254 (maximun) value.
pkhatri Thu, 03/16/2006 - 03:47
Can you do a screen capture (log) of what you are typing in, followed by a 'sh run' and then post the output ? There's something weird going on...
Paresh
comechivos Thu, 03/16/2006 - 04:31
I just do what you are saying,
by the time, everythin is ok, But when I reboot or shutdown the interface and bring it back again the administrative distance changes to 254 again.
thats all I do.
comechivos Thu, 03/16/2006 - 09:55
mm, I think is done, I set the administrative distance of the T1 line to 255, bigger than the cablemoden automatic, so I think its done, but Im not sure, because I cant shut down the router right now, I tested the failover, it worked fine, the only problem was the administrative distance that I think is fixed now.so, tomorrow I ll test everithing.
Thank you so much
comechivos Fri, 03/17/2006 - 03:50
nop, It didnt work with a 255 administrative distance value....
any idea?
pkhatri Fri, 03/17/2006 - 16:24
An admin distance of 255 makes the route unreachable. You can use any non-255 AD as long as the AD for the preferred route is less than that for the backup route.
Paresh
comechivos Sat, 03/18/2006 - 08:23
yes I know that, but the cablemodem line has an 254 value, and I cannot change it, when I change it, goes back to 254 automatically., so I need to make that static.
can you understand me? maybe not, because my english is so bad, because I m from Argentina.
sorry about that
pkhatri Mon, 03/20/2006 - 14:49
Your English is fine, mate :-)
What I am having trouble with is how you keep getting the AD of 254 on your static route. That is very odd and does not work in reality.
Also, I noticed that you posted your config earlier but it seems to have disappeared now. Could you re-post it ?
Paresh
comechivos Tue, 03/21/2006 - 04:02
is there anyway to put the T1 interface in standby?
when the cablemodem fail. the T1 interface set active. and when the cablemodem is up again the T1 interface goes back to standby mode.
is this possible? because the router is routing against the T1 and I dont want that when the cablemodem is up.
