03-15-2006 07:32 AM - edited 03-18-2019 05:41 PM
Unity 4.05, seems to be working, event viewer clean. Tray icon stuck pointing up.
Any suggestions? This is a new install, VM only, member server in domain, CCM integrated. Ports registered and Unity is answering.
03-15-2006 07:50 AM
Update: Tray icon doesn't change when you stop or start Unity
03-15-2006 08:23 AM
Once the tray icon looses it's connection to the running status of Unity, you have to unload it and reload it - this happens now and again. Just right click on it and select "exit" to unload it and then run "CsTrayStatus.exe" from the \commserver\ installation directory. It will reestablish the connection to the gateway and show the proper status of Unity again.
