Access Lists and NAT
Answered Question
Mar 15th, 2006
Can you use NAT in combination with ACLs to forward packets that come in on an interface on a specific port (8001)to a specific device on a different port (80)? This is on a router, not a PIX.
If so, then how?
Correct Answer by pkhatri about 11 years 5 months ago
You certainly can. Here's an example
interface Ethernet0
ip nat inside
interface Serial0
ip nat outside
ip nat inside source static tcp 10.1.1.1 80 200.1.1.1 8001
OR
ip nat inside source static tcp 10.1.1.1 80 serial0 8001
Hope that helps - pls rate the post if it does.
Paresh
Overall Rating: 5 (1 ratings)
Correct Answer
pkhatri Wed, 03/15/2006 - 12:45
  • Purple, 4500 points or more
interface Ethernet0
ip nat inside
interface Serial0
ip nat outside
OR
Paresh
jackko Wed, 03/15/2006 - 15:42
  • Gold, 750 points or more
just a quick add-on.
the inbound acl would be on the public ip, not the private ip.
e.g.
access-list 111 permit tcp any host 200.1.1.1 eq 8001
interface s0
ip access-group 111 in
