External/Internal dial plan
Mar 15th, 2006
I have a multiseites WAN centralized call processing cluster with over than 50 sites. the dial
- XYYYZ where
* X : region code
* YYY : site code
* Z:numbers for this site
Ex: site 107 in region 2 has numbers :
21070 to 21079. that is the global dial plan, but i want use just two digit for internal calls in the same site(XX).
Please if someone have any idea ?
Thanks.
Overall Rating: 3 (1 ratings)
gogasca Wed, 03/15/2006 - 19:37
  • Green, 3000 points or more
2 107 0 - 2 107 9.
If you want to use only 2 digits dial for intrasite dialing, I would create different CSS (Calling Search Space) and partitions for each site.
So each site will be able to reach all different sites, lets say.
In this Region: 2
In this Site: 107.
Numbers: 0-9
Translation Pattern:
00 - 2 107 0
I would restrict a number(s) for the region code to be used. (Regions can only use numbers [2,3,4,5,6,7,8,9)
So we reserved 0 and 1 for intra-dialing.(00-19)
So each extension in every site can dial only 2 numbers. (use a Translation Pattern and CSS to restrict the access for its local numbers converting a 00 into 21070 or a 01 into a 21071),....
I expected that the real extension is 21070|21079 and using Translation Patterns (TP) and option Called Party transform mask within the TP help you.
So each site can access its local Translation Pattern.
CSS: Site107
Partitions:Site107pt
Otherregions
Extension 21070 in partition Otherregions
CSS: Site107
TP [01][0-9] in partition Site107pt
CSS: Site107
Called Party Transform Mask 2107X
Let me know
//G
