3750 switch stacks
Mar 15th, 2006
I am new to the networking world and have some questions.
I have 1 stack of six 3750 switches with a 10.50.3.10 ip address
On the first stack (.10)I have int 6/0/19 , 20 and 21 assigned.
I have a second ip scheme with one switch with an ip of 10.50.3.11
Do I use a smartwise cable to connect the switches even though they have different ip schemes? Or do I use a only a cat 5 to connect the 2 differenet stacks. Also, do I need to configure the 6/0/19, 20 and 21 ports on the second ip scheme. I don't think it is possible now that I am writing this if the smartwise cables are not used. Any help would be appreciated.
Roberto Salazar Wed, 03/15/2006 - 21:37
  • Gold, 750 points or more
I apologize but I am not following you entirely. If you stack the 3750, you must use the stacking port and use the stackwise cable.
You said: I have 1 stack of six 3750 switches with a 10.50.3.10 ip address
>> This would mean you stacked them using the stackwise cable and all these six switches are seen as one single device.
What do you mean by you have int 6/0/19-21 assigned? Assigned them what?
You said: I have a second ip scheme with one switch with an ip of 10.50.3.11
>> Sounds like you have another stack? Because the device will complaint if you address two different interfaces in teh same switch/router to the same subnet (10.50.3.10 and 10.50.3.11), unless these addresses are masked as host but I doubt that.
