Hi Gary,
The message is a bit misleading. The "system restarted" message is coming from the CFC daughter card on the module
"%SYS-CFC9-5-RESTART: System restarted -"
So the entire switch did not restart, but just the module and daughter card. Now, I'm saying that based on the provided messages. You should check the system uptime in the "show ver" and/or the reset logs stored in the NVRAM log "show log" as well.
But, as I said, if the only indication of "System restarted" was in the above syslog, then that's only referring to the CFC.
HTH,
Bobby
