Warning message
VPN PPTP with Radius
Mar 16th, 2006
Hello All...
I´m configuring VPN PPTP on Cisco Router, and when I configure authentication LOCAL, it is work fine.
Now I want to use Radius Server, and I have this configuration:
aaa new-model
aaa authentication login default local
aaa authentication ppp VPNWEB group radius local
aaa authorization network VPNWEB group radius if-authenticated local
vpdn enable
vpdn ip udp ignore checksum
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
interface Virtual-Template1
ip unnumbered FastEthernet0/1
peer default ip address pool VPNWEB-POOL
no keepalive
ppp encrypt mppe auto required
ppp authentication ms-chap ms-chap-v2 pap chap VPNWEB
radius-server host Y.Y.Y.Y auth-port 1812 acct-port 1813
radius-server key XXXXX
This is my configuration on cisco router. Is it correct?
I´m using Free Radius on Linux.
Thanks all...
Cassio Gomes
smalkeric Wed, 03/22/2006 - 11:01
  • Silver, 250 points or more
Few RADIUS servers support Microsoft Point-to-Point Encryption (MPPE). To use the vpdn group group-name ppp encryption mppe command in the PIX, the RADIUS server must support MPPE.
MPPE is supported only in some RADIUS servers (not in TACACS+ servers). Three RADIUS servers that support MPPE are:
Cisco Secure 2.5 and later
Funk RADIUS
Microsoft IAS
