Warning message
ACL to access with telnet on my Router 837
Mar 16th, 2006
i have a router 837 with one interface adsl and one loopback interface configured all two interface with pubblic ip address.
I would want make acl that permit me to telnet in loopaback interface but not in adsl (atm 0.1) interface.
I have tried with access list and access class but the access list was applied to all interface.
Example:
interface loopback 0
ip address xx.xx.xx.231 255.255.255.252
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address xx.xx.xx.230 255.255.255.252
Overall Rating: 2.3 (3 ratings)
pkhatri Thu, 03/16/2006 - 09:23
  • Purple, 4500 points or more
Try this:
access-list 101 permit ip any host x.x.x.231
line vty 0 4
access-class 101 in
Hope that helps - pls rate the post if it does.
Paresh
e.deangelis Fri, 03/17/2006 - 00:45
Hi Paresh,
thanks for your reply, but i not work.
Strange, but i not telnet router in any interface with this acl.
pkhatri Fri, 03/17/2006 - 00:49
Do you have any ACLs applied on any of the interfaces at all ?
Paresh
e.deangelis Fri, 03/17/2006 - 01:47
in loopback interface no.
I have acl in ethernet interface.
ip access-list extended FIREWALL
access-list 110 permit ip 192.168.11.0 0.0.0.255 192.168.149.0 0.0.0.255
access-list 110 permit ip 192.168.11.0 0.0.0.255 192.168.150.0 0.0.0.255
access-list 110 permit ip 192.168.11.0 0.0.0.255 192.168.17.0 0.0.0.255
access-list 110 permit tcp any any eq www
access-list 110 permit tcp any any eq 443
access-list 110 permit tcp any any eq domain
access-list 110 permit icmp any any echo
access-list 110 permit tcp any eq ftp-data any gt 1023
access-list 110 permit tcp any eq ftp any gt 1023
nethelper Fri, 03/17/2006 - 03:49
  • Silver, 250 points or more
try and add a log statement to the access list:
access-list 110 deny ip any any log
If your access is blocked by the access list, it should show in the console output of your router.
You could also try and add the following to your access list:
access-list 110 permit tcp any any eq telnet
Nethelper
e.deangelis Fri, 03/17/2006 - 04:12
Nethelper,
thanks in advance,
but i have a problem on loopback interface.
i have two external interface, atm 0.1 with ip of provider and loopback interface with my ip address.
I want that the telnet work only on the loopback interface.
see my example configuration.
nethelper Fri, 03/17/2006 - 04:57
understood, but keep in mind that the Loopback interface is not an external interface, it is just a virtual interface that is neither internal nor external. If your TELNET clients are coming from behind the Ethernet0 interface, the access list you applied to that interface will block access to the Loopback interface, that is why I recommended the additions to the access list.
Check the access list operation first by adding the ´log´ keyword to the deny statement as described, and if you see that the access list blocks your Telnet access, add the line:
access-list 110 permit tcp any host x.x.x.231 eq telnet
Does that make sense ?
Nethelper
e.deangelis Fri, 03/17/2006 - 05:30
ok thanks,
please see my config:
I would want telnet only in loopback interface.
_________________________
version 12.3
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname ******
enable password ******
username ***** privilege 15 password *******
aaa new-model
aaa authentication login console enable
aaa authentication login telnet local
aaa authentication ppp default none
aaa authorization exec console none
aaa authorization exec telnet local
aaa session-id common
ip subnet-zero
ip multicast-routing
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
crypto isakmp policy 11
hash md5
authentication pre-share
crypto isakmp key 6 ******** address xxx.xxx.xxx.xxx
crypto ipsec transform-set VPN esp-des esp-md5-hmac
crypto map nolan 11 ipsec-isakmp
set peer xxx.xxx.xxx.xxx
set transform-set VPN
match address 120
interface Loopback0
ip address yyy.yyy.yyy.218 255.255.255.248
crypto map nolan
interface Ethernet0
ip address 192.168.13.1 255.255.255.0
ip nat inside
no ip mroute-cache
hold-queue 100 out
interface ATM0
no ip address
ip address xxx.xxx.xxx.230 255.255.255.252
ip nat outside
pvc 8/35
encapsulation aal5snap
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
ip nat inside source list 101 interface Loopback0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xyz.229
ip route 192.168.17.0 255.255.255.0 Loopback0
ip route 192.168.149.0 255.255.255.0 Loopback0
ip route 192.168.150.0 255.255.255.0 Loopback0
no ip http server
no ip http secure-server
access-list 101 deny ip any 192.168.149.0 0.0.0.255
access-list 101 deny ip any 192.168.150.0 0.0.0.255
access-list 101 deny ip any 192.168.17.0 0.0.0.255
access-list 101 permit ip 192.168.13.0 0.0.0.255 any
access-list 120 permit ip 192.168.13.0 0.0.0.255 192.168.149.0 0.0.0.255
access-list 120 permit ip 192.168.13.0 0.0.0.255 192.168.150.0 0.0.0.255
access-list 120 permit ip 192.168.13.0 0.0.0.255 192.168.17.0 0.0.0.255
line con 0
login authentication console
no modem enable
stopbits 1
line aux 0
line vty 0 4
exec-timeout 30 0
password *********
login authentication telnet
length 0
scheduler max-task-time 5000
end
