Warning message
site2site with failover
Mar 16th, 2006
I am trying to setup a site to site vpn on two 515e pix running version 7. Both pix have three interfaces. I am trying to configure the failover using osfp on both pix. One tunnel will go through the internet and the other one will go through a dsl line.
I think this is a new feature in pix version 7 and i am worried about going to the customer site and not sure what to do.Does someone have a template that i can use?
Any help will be greatly appreciated.
Lake
s-doyle Wed, 03/22/2006 - 13:40
Your requirement is not very clear to me. What do you mean by "failover using OSPF"? Are you trying to manipulate OSPF metrics to do a failover configuration?
Lharrypersaud Thu, 03/23/2006 - 05:37
I was trying to setup a vpn to connect to two different using isp and using ospf on the pix with two external interfaces. I worked with Cisco tech and we got it working.
Thanks for your help
Lake
jackko Fri, 03/24/2006 - 22:39
  • Gold, 750 points or more
failover with different isp is not feasible, as both primary and secondary units share the same config including the ip.
