Warning message
VPN Issues
Mar 16th, 2006
Is there is any relationship between SSH and VPN.
I did a VPN configuration in my router and to get connected using the Cisco VPN client. The VPN worked fine and was able to connect reomtely.
Then i applied set of commands for SSH. I can use putty to telnet the router. Now, i cannot create a VPN tunnel between my laptop and the router. Is there is any connetion between SSH and VPN configurations ???
Thanks in advance...
Rajesh
kradjesh13 Thu, 03/16/2006 - 21:40
Sorry guys,
Its all because of mee and my mistake.
Problem fixed.
Rajesh
