VLAN Bandwidth Management
Mar 17th, 2006
How we can share a Bandwidth in a VLAN,
I mean share a Bandwidth in a single VALN Clients,
can we do it through a IOS configuration or is there any hardware for this solution,
Note: Currently we are using L3(3550) & L2(2950) switches.
L2 in VTP client Mode, L3 in VTP Server Mode, and all VLANS are creat in L3 Switches.
Thank You
nethelper Fri, 03/17/2006 - 05:38
  • Silver, 250 points or more
what exactly are you trying to accomplish ? Do you want to assign a certain bandwidth to a single client in a VLAN ?
Nethelper
mansoor_nawaz78 Fri, 03/17/2006 - 19:57
Thank You, for a reply,
I would like to share a Bandwidth between all Clients of VLAN, e.g
If i define a VLAN "320" i apply a fix bandwidth to this VLAN, 256Kbps, now every client of this VLAN share this bandwidth, if 4 Client in VLAN 320, every client share 64K, if 10 Client in 320 VLAN every cleint share 25.6K Bandwidth.
I am waiting for ur reply,
Thank You Again
nethelper Sat, 03/18/2006 - 00:23
Hello Mansoor,
understood, thanks for the clarification. I am not sure if this sort of dynamic bandwidth allocation is possible with just the IOS on the 3750. You can definitely police the bandwidth per user, but this would be a static allocation:
policy-map LIMIT_BANDWIDTH
class class-default
police 100000 12500 exceed-action policed-dscp-transmit
interface FastEthernet0/1
service-policy output LIMIT_BANDWIDTH
service-policy input LIMIT_BANDWIDTH
This example would limit each port to 100K of traffic, in case more traffic is sent, that traffic would be marked down according to a policed DSCP map...
Nethelper
mansoor_nawaz78 Sat, 03/18/2006 - 01:14
Ok thank you,
I am using this sort of configuration, but i would like to limt the Bandwidth in a VLAN.
