Warning message
pralex Fri, 03/17/2006 - 06:18
  • Cisco Employee,
It is possible to record conversations with IPCC Express.
1.Agents can record a customer call.
2.Supervisors can record an agent's call.
m.paolelli Fri, 03/17/2006 - 08:13
Thanks for answer.
Can you do that directly with Cisco or you need a Third Party Tool?
sanjeev.thallik... Fri, 03/17/2006 - 12:33
  • Silver, 250 points or more
Cisco IPCC Express supports recording as long you purchase the corresponding licenses for that. Because the recording service etc gets installed based on the license file. So, if you license does not have it, then it will not be installed.
Please rate posts
