Fibre Patch Lead Choice with FCIP
Answered Question
Mar 17th, 2006
I have a solution to implement and connect 2 MDS 9509s. Distances involved in fibre runs are sub 150m. Is there any benefit in me using 50/125 instead of 62.5/125 within these distances. The existing infrastructure would dictate that we run with 62.5/125. We may want to run with up to 10Gb over the Fibre, but as this will be aggregated through port channels I don't see the fibre choice as being an issue so long as we don't interface 62.5 with 50 directly... Can anyone confirm that this is ok?
Paul
Correct Answer by pciaccio about 11 years 5 months ago
Theoretically the 50um fiber is the better and is primarily used for longer lengths of 500+meters. You can use either type for your application. It will work fine. The only benfit the 50um offers is a smaller diameter that allows for less dispersion loss and goes a longer distance. Yes, I would stay with one type of fibr. Do not mix and match...Please rate..Good Luck...
Overall Rating: 5 (1 ratings)
Correct Answer
pciaccio Fri, 03/17/2006 - 09:12
  • Silver, 250 points or more
p-matthewson Sat, 03/18/2006 - 09:58
Thanks for your response - I will go with 50um in the solution. Cheers, Paul
Trending Topics: Storage Networking
