Warning message
time slot proofs
Mar 18th, 2006
can anyone tell me why we using 51.2microseconds for time slots?
or 512bit as the minimum frame size?
i've tried to calculate that
x=(2500*2(distance))/(2*10(8))
it get 25micsecond
pkhatri Sat, 03/18/2006 - 16:27
  • Purple, 4500 points or more
It comes from the following:
Minimum size of ethernet frame = 64 bytes = 512 bits
Time taken to transmit a minimum size ethernet frame on a 10Mbits link = 512/10,000,000 = 51.2 microseconds.
Hope that helps - pls rate the post if it does.
Paresh
haplo1213 Sat, 03/18/2006 - 22:46
yes , but why 512bits?
why IEEE802.3 choosed this number to be the minimum frame size? what was the calculation ?
i couldnt find any normal answer on google.
the one-trip propogation delay is 12.5uSeconds (for 2500M cable)..
two round-trips 25uSeconds....? why not 250bit?
pkhatri Sun, 03/19/2006 - 15:11
As you worked out, the round-trip time would be around 25 microseconds. From what I understand, the IEEE decided to build in a safety margin when deciding on the 512 bits minimum frame size.
Paresh
haplo1213 Sun, 03/19/2006 - 19:24
yeah that's the minimum frame, but why .
i made some research on that
here's the results.
we need to discovre the total path delay.
25us for 2500 cable
4 repeaters class I add 0.7us for each repeater
DTE delay
and safety margin
so
total delay=link delay+repater delay+DTE delay+saftey margin
that should come out 51.2us :))
still need to get the numbers thu
