Warning message
How to configure SDM v22 Firewall congi to allow in SMTP to my Exch Srvr
Mar 19th, 2006
Hello
I am trying to configure my 1811W firewall config via SDM to send inbound smtp traffic to my exchange server...easy setup as I am a small copany with a small network yet its been about 6 hrs now and I cant get it to work.
Info
I have two interfaces - one WAN IP (FE1) and LAN IP configured on 1811
FW Policies/ACL/rules are as follows:
From WAN/FE1 to LAN
-FROM ANY to the LAN IP address of my Exchange Server for SMTP at Port 25
-From ANY to the LAN IP Address of my 1811 Router for SMTP at Port 25
The only denies I have are
From 0.0.0.0 to any and the other private addresses
Do I have to do anything else??
HELP!! Thanks in advance
tomricher Sun, 03/19/2006 - 15:04
How do I post the config in SDM? (Extreme newbie/First day doing Cisco firewalls) :-)
froggy3132000 Sun, 03/19/2006 - 15:24
  • Bronze, 100 points or more
If you don't have ssh or telnet access, in SDM you can click on the "VIEW" tab at the top and select running config. Copy and paste the remove your outside ip address for security reasons.
froggy3132000 Sun, 03/19/2006 - 15:30
OK, you need to have a PAT on the outside interface.
Something like this
ip nat inside source static tcp 25 interface fastethernet1 25
tomricher Sun, 03/19/2006 - 15:34
how do i do that through the sdm gui? I am not technical - thx
tomricher Sun, 03/19/2006 - 16:02
Hi froggy
how do i add the PAT through the sdm gui? what is a PAT? I am not technical sorry
Thx.
froggy3132000 Sun, 03/19/2006 - 16:13
do you only have access to the gui? not ssh or telnet?
I honestly have not used sdm that much to know where to configure PAT. It should be fairly simple through the gui. One thing I did notice about your config is your BVI is your internal interface. What type of connection do you have to the Internet?
tomricher Sun, 03/19/2006 - 16:43
Great article thx
To your other questions, I have Telnet built into SDM and I have a T1 to the Internet
I did find it (I believe in the gui) under NAT
Under NAT in the GUI, it now shows:
Original Addres = 192.168.1.201 (25)
Translated address = Public IP address (25)
You mentioned BVI I dont know how I got that, I followed an EZ setup wizard...should I try and change that?
tomricher Sun, 03/19/2006 - 17:18
Update
I reset to factpry default and this time i did not build it with vlan
made PAT entry still doesnt work
attaching new config
froggy3132000 Sun, 03/19/2006 - 17:43
your pat statement needs to be on fastethernet 1
That is your outside interface.
froggy3132000 Sun, 03/19/2006 - 17:49
tomricher Sun, 03/19/2006 - 18:16
This PAT change is now causing an IP address conflict with my exchange server!Help
tomricher Sun, 03/19/2006 - 18:24
You mentioned the statement
above
but when I configure it on the outside address it lists
ip nat outside source static tcp 25 interface fastethernet1 25
in the config file
should it be
or
ip nat inside source static tcp 25 interface fastethernet1 25???
thx
