FXs Problem busy tone
Mar 20th, 2006
i have fxs port in router 3845,
i configured it , whenever i dial it ,it gives me busy tone always ,and there is no call
the problem with port 1/0/1
ElGomhurya_2#sh voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
1/0/0 -- fxs-ls up dorm on-hook idle y
1/0/1 -- fxs-ls up up on-hook idle y
1/1/0 -- fxs-ls up dorm on-hook idle y
1/1/1 -- fxs-ls up dorm on-hook idle y
voice-port 1/0/0
timeouts interdigit 2
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
dial-peer cor custom
dial-peer voice 2222 pots
destination-pattern 2222
port 1/0/0
dial-peer voice 1 voip
destination-pattern .T
session target ipv4:172.21.100.1
dial-peer voice 8833 pots
destination-pattern 8833
port 1/1/0
dial-peer voice 6677 pots
destination-pattern 6677
port 1/1/1
dial-peer voice 1234 pots
destination-pattern 1234
port 1/0/1
spremkumar Mon, 03/20/2006 - 06:31
  • Red, 2250 points or more
Can you post out the config related to the dial peer POTS and VOIP ? also whether you have enabled the voice ports which is instaled in the router..
regds
davidcruise Mon, 03/20/2006 - 13:12
2222
8833
6677 working normally
but 1234 gives me busy tone whenever i dial it
darren.staples@... Thu, 10/04/2007 - 14:30
I am having the same problem
have a vg224 with multiple faxes.
When call from fax to fax completes the port
is fine (dormant/onhook)
but when a call is incomplete, like if you call from your phone, (hear the fax attempt negotiation), then hangup.
that port's state remains up (up/onhook) and until reset the port, it is not usable.
have tried adding "timeouts call-disconect 10"
and "timesout wait-release 10", reset the port, but made no difference. then changed the 10 to 5 - no help. removed call-disconnect and left just wait-release - no help.
any ideas?
