Warning message
Deleting an RSA key pair file on CSS 11501
I have tried using the "clear ssl file" command to remove an old RSA key pair file as described in a previous thread. However, this requires me to "enter the password used to 3DES encode the file". Unfortunately, I do not have the password any more. Is there a way to remove the ssl file anyway (without removing other files)?
Thanks in advance!
Harald
kelvin-yeo Tue, 03/21/2006 - 04:41
Harald,
Unfortunately,if the original key was generated on the CSS and the hashing password is lost, there is no way to get the key
cheers
