Warning message
configuring command level authorisation
Mar 20th, 2006
hi could someone pls tell me where on the acs to configure the command level authorisation for users to access the routers.pls help i am new to this. i am also using a evaluation copy of it.
sebastan
m.sir Tue, 03/21/2006 - 04:29
  • Gold, 750 points or more
It should be - shared profile components - Shell Command Authorization Sets - select ADD for new set - type name and description and to left window write command and to the right subcommands, than you have to in group properities bind this profile to group.....
rate useful posts
sebastan_bach Tue, 03/21/2006 - 10:25
hi thanks for ur input. can u pls help me in little more detail. thank u once again
sebastan
