Warning message
QOS Best Effort Policy - utilization on a 2851 Multi Link Int.
Mar 20th, 2006
We have QOS configured on a 2851 (12.4.5)
and applied to Multi Link Interface 1 made up of 3 T1s. We want to limit Best effort to 800K. But most of the time we see that FTP and other connections exceed 800K. We are wondering if the Best Effort policy only limits traffic if one or both or the other policies for Citrix or Voice are congested enough to exceed the 1024K prioity we have configured for them. Appreciate any enlightenment on how this should work.
Below are the QOS configs
class-map match-all CITRIX
match access-group name citrix
class-map match-all BEST-EFFORT
match access-group name best-effort
class-map match-all FTP
match access-group name ftp
class-map match-any VOICE
match ip precedence 5
policy-map mu1
class VOICE
priority 1024
set ip precedence 5
class CITRIX
set ip precedence 4
bandwidth 1024
class BEST-EFFORT
set ip precedence 0
shape average 800000
class class-default
fair-queue
random-detect
ip access-list extended best-effort
permit tcp any eq 445 any
permit tcp any eq ftp-data any
permit tcp any eq 8086 any
permit tcp any eq www any
permit ip host 10.7.4.104 any
pkhatri Mon, 03/20/2006 - 21:49
  • Purple, 4500 points or more
One very probable issue is that the access-list that you have configured for best-effort is not capturing all the FTP traffic. FTP (depending on whether its active/passive and whether it's from a client or server) will use ports other than the 2 well-known ports for data transfer.
I suggest you configure your class-map as follows:
class-map match-any BEST-EFFORT
match protocol ftp
Note that it has to be 'match-any' and NOT 'match-all'
Hope that helps - pls rate the post if it does.
Paresh
