Warning message
network boot using tftp
Mar 21st, 2006
I have 3725 router. due to insufficient flash i would like to boot the router using tftp.
I want to know command to proceed.
will i be able to download 64 mb file into memory.
Richard Burts Tue, 03/21/2006 - 08:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
kamalnath
You would need to verify that you have enough memory on your 3725 to run this new version of IOS. But if you do then you can use this command:
boot system tftp
Rick
