ServeRaid error after WIN-OS upgrade
Mar 22nd, 2006
  • Silver, 250 points or more
I have two MCS7835I-3000 IBMX345 Servers. I recently
installed the following patches win-OS-Upgrade-K9.2000-4-2.exe,
win-OS-Upgrade-K9.2000-4-2sr4.exe and I'm now getting the following error:
ServeRAID: version mismatch detected: controller 1 . The BIOS (Ver 7.12.02),
Firmware (Ver 7.12.02) and Driver (Ver 6.10.24) are not a matced set and are
not compatible. I can also no longer access ServeRAID Manager!!
Overall Rating: 3 (1 ratings)
jbarcena Wed, 03/22/2006 - 12:56
  • Red, 2250 points or more
Yes, sometimes the the BIOS,firmware and driver should be on the same level and that is your problem. You can open a TAC case so they open a case with IBM to give you the correct link or CD to upgrade this.
Here is a link that was useful once ago with the same case but not sure if it has the versions that you need
http://www-1.ibm.com/support/docview.wss?uid=psg1MIGR-60624
dezoconnor Thu, 03/23/2006 - 03:24
Hi, thanks for the reply. I've a TAC case open so waiting for their response! Is it a simple procedure to upgrade BIOS, firmware or drivers? Whats the chance that I could lose everything?
jbarcena Thu, 03/23/2006 - 05:44
I had only one customer with that issue and everything went without any problem. Looking at our database for similar cases I did not found one with issues in the upgrade. I think that you should be fine. =)
