Weird Config
Answered Question
I have two 3750’s connected by a dot1q trunk and a switchport access link (see Visio attachment). I want all vlan traffic except vlan 100 to route through the trunk and only vlan100 to route through the switchport access link. Will this configuration work? I’ve included the switch configs.
Correct Answer by bhedlund about 11 years 5 months ago
If you require Layer2 COS markings present in the frames then yes this would be better.
Please rate all helpful posts.
Brad
Overall Rating: 5 (3 ratings)
pkhatri Wed, 03/22/2006 - 17:19
  • Purple, 4500 points or more
Your config looks fine and it should work.
Paresh
Just one thing you can do to verify this: enter 'show interface trunk' on the 3750s to make sure that VLAN 100 is not being passed over the trunk links.
Hope that helps - pls rate the post if it does.
Paresh
Correct Answer
bhedlund Thu, 03/23/2006 - 09:50
  • Silver, 250 points or more
Brad
