Software to test RADIUS/TACACS authentication to ACS server
Mar 23rd, 2006
Hi experts,
Is anyone aware of a software that will test RADIUS and/or TACACS authentication to an ACS server from a PC? Same as what you can do on the Cisco VPN concentrator from the page Configuration | System | Servers | Authentication | Test Screen.
Thanks in advance!
Overall Rating: 4 (2 ratings)
darpotter Fri, 03/24/2006 - 12:52
  • Silver, 250 points or more
If you look in the ACS utils folder you'll see radtest and tactest.exe
These can be used to generate test packets. If you install ACS on another PC you can fire requests from that other PC too.
I think Vasco (token card vendor) had a really nice GUI based RADIUS client too.
Darran
