Cisco 837 - SDSL 512/512 or not ?
Mar 23rd, 2006
Just wondering if anyone knows if the Cisco 837 can be configured for a 512/512 SDSL connection? The SDSL connection is just a bridge connection (/30) where you get one static IP and the other static IP is the gateway on Telstra's end.
If the 837 can support a SDSL connection, does anyone have a config for it? Or would the config be the same as a ADSL bridge connection?
Thanks in advance.
Overall Rating: 2 (1 ratings)
whiteford Fri, 03/24/2006 - 00:57
I think the 878 supports SDSL (G.SHDSL). The 877 router supports ADSL2/ADSL2+ and is very similar to the 837.
pkhatri Fri, 03/24/2006 - 01:02
  • Purple, 4500 points or more
We've used the 837 for 'symmetric' ADSL rates of up to 512k/512k.... However, the problem I see is that you are hoping to use this router for an SHDSL link - that is not possible with the 837 and as the previous poster mentioned, you will need to look at a different platform.
I have used the 828 and also the 1721 + WIC-1SHDSL on the Telstra network but I'm sure the newer platforms would work just as well...
Hope that helps - pls rate the post if it does.
Paresh
andysaykao Sun, 03/26/2006 - 13:50
Thanks for all your replies.
I'm using a standard bridge config on the 837 with pvc set to 8/35 but debug all is giving me weird results. Can anyone interpret the debug?
*Mar 1 00:02:33.043: ILMI(ATM0): Sending ilmiColdStart trap
*Mar 1 00:02:33.043: ILMI(ATM0): No ILMI VC found
*Mar 1 00:02:33.043: ILMI: Encapsulation error on o/g ILMI Pdu (ATM0)
*Mar 1 00:02:33.043: ILMI: Unable to Send Pdu out
*Mar 1 00:02:33.055: STP: opt: Bridge group 1: get ports: no free chunk available
*Mar 1 00:02:33.055: ATM0(O):
Here is a snip of the ATM interface.
interface ATM0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
bridge-group 1
hold-queue 224 in
pvc 8/35
encapsulation aal5snap
