Warning message
AXL Serviceability
Mar 27th, 2006
  • Silver, 250 points or more
Did anyone got the RISPort working?
I have tried with raw coding, but the request is not accepted;
sAXLSOAPRequest = "POST /Soap/astsvc.dll HTTP/1.0\r\n";
sAXLSOAPRequest += "Host: "+_HOST+":80\r\n";
sAXLSOAPRequest += "Authorization: Basic "+_AUTH+"\r\n";
sAXLSOAPRequest += "Accept: text/*\r\n";
sAXLSOAPRequest += "Content-type: text/xml\r\n";
sAXLSOAPRequest += "SOAPAction: \"http://schemas.cisco.com/ast/soap/action/#RisPort#SelectCmDevices\"\r\n";
sAXLSOAPRequest += "Content-length: ";
sAXLRequest = "<?xml version=\"1.0\" encoding=\"utf-8\"?>";
sAXLRequest += "<soap:Envelope xmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\" ";
sAXLRequest += "xmlns:soapenc=\"http://schemas.xmlsoap.org/soap/encoding/\" ";
sAXLRequest += "xmlns:tns=\"http://schemas.cisco.com/ast/soap/\" ";
sAXLRequest += "xmlns:types=\"http://schemas.cisco.com/ast/soap/encodedTypes\" ";
sAXLRequest += "xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" ";
sAXLRequest += "xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\">";
sAXLRequest += "<soap:Header><tns:AstHeader id=\"id1\"><SessionId xsi:type=\"xsd:string\">123456987</SessionId></tns:AstHeader></soap:Header>";
sAXLRequest += "<soap:Body soap:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><tns:SelectCmDevices>";
sAXLRequest += "<StateInfo xsi:type=\"xsd:string\" />";
sAXLRequest += "<CmSelectionCriteria href=\"#id1\"/>";
sAXLRequest += "</tns:SelectCmDevices><tns:CmSelectionCriteria id=\"id1\" ";
sAXLRequest += "xsi:type=\"tns:CmSelectionCriteria\">";
sAXLRequest += "<MaxReturnedDevices xsi:type=\"xsd:unsignedInt\">10</MaxReturnedDevices>";
sAXLRequest += "<Class xsi:type=\"tns:DeviceClass\">Any</Class>";
sAXLRequest += "<Model xsi:type=\"xsd:unsignedInt\">255</Model>";
sAXLRequest += "<Status xsi:type=\"tns:CmDevRegStat\">Any</Status>";
sAXLRequest += "<SelectBy xsi:type=\"tns:CmSelectBy\">Name</SelectBy>";
sAXLRequest += "<SelectItems href=\"#id2\" />SEP00127F2E618C</tns:CmSelectionCriteria>";
sAXLRequest += "<soapenc:Array id=\"id2\" soapenc:arrayType=\"tns:SelectItem[2]\">";
sAXLRequest += "<Item href=\"#id3\"/><Item xsi:null=\"1\"/>";
sAXLRequest += "</soapenc:Array>";
sAXLRequest += "<tns:SelectItem id=\"id3\" xsi:type=\"tns:SelectItem\">";
sAXLRequest += "<Item xsi:type=\"xsd:string\"/></tns:SelectItem>";
sAXLRequest += "</soap:Body></soap:Envelope>";
response:
HTTP/1.1 500 ERROR
Server: Microsoft-IIS/5.0
Date: Tue, 28 Mar 2006 03:54:12 GMT
X-Application: XXX
Expires: Sat, 1 Jan 2000 00:00:01 GMT
Cache-Control: No-Cache
Pragma: No-Cache
Connection: Keep-Alive
Content-Type: text/xml; charset="utf-8"
Content-Length: 946
<?xml version="1.0" encoding="UTF-8" standalone="no"?><SOAP-ENV:Envelope SOAP-EN
V:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http
://schemas.xmlsoap.org/soap/envelope/" xmlns:SOAP-ENC="http://schemas.xmlsoap.or
g/soap/encoding/"><SOAP-ENV:Body><SOAP-ENV:Fault><faultcode>SOAP-ENV:Client</fau
ltcode><faultstring>Operation name is not valid</faultstring><detail><m:ErrorInf
o xmlns:m="http://schemas.cisco.com/ast/soap/"><Version>3.2.0.7</Version><Time>0
3/28/2006 - 15:54:12</Time><ProcId>5876</ProcId><ThreadId>3852</ThreadId><ArrayO
fCallInfo SOAP-ENC:arrayType='m:CallInfoType[]'><CallInfo><FileName>D:\Builds\ES
BUILD_4.1.3.sr.1\ccm_sw\Projects\AST\ISAPI\server\soap\service\port\risport\rism
ain.cpp</FileName><LineNo>344</LineNo><ErrorCode>0</ErrorCode><Function>Lookup
</Function><Params>SelectCmDevices</Params></CallInfo></ArrayOfCallInfo></m:Erro
rInfo></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
