IPS5x page error
Mar 27th, 2006
As I imorted my 5.x IPS sensor into my VMS system and click on the IPS 5.x Signature page, the following message is showing:
Object loading failed. SignatureGroups(boolean): Unable to load and parse signature groups document.
I tried to re-importor delete and import the sensor back, but the sameerroe appears.
Any Idea?
Overall Rating: 5 (1 ratings)
b.hsu Fri, 03/31/2006 - 12:29
  • Silver, 250 points or more
This error message usually indicates a database problem. If rebooting the machine and/ or restarting the services does not solve the problem, and if the problem has always existed, then usually the fastest way to get it solved is to reinstall the application.
carudd_426 Thu, 05/04/2006 - 10:52
Thank you jbolling you hit the nail on the head. I upgraded just as you suggested and the problem is corrected.
Thank you again !!!!!
