Problem CiscoWorks vs ACS
Mar 28th, 2006
Hello
When I associate the ciscoworks with the ACS, it gets down some process like CTMJrmServer and Datapurge and i can´t started it again. It deleted my jobs, and show me this message: CRIN0014: Operation failed, caused by failure in connecting to JRM. Make sure jrm and/or CTMJrmWrapper services are running.
Overall Rating: 5 (1 ratings)
Drid Tue, 03/28/2006 - 12:34
actually just fixed my problem.. it required a user in the group that the shared components is associated with
mserwon Fri, 03/31/2006 - 09:27
I have this problem also. Did you add an additional user in ACS? Or did you add your ciscoworks admin user into ACS?
barryjones Fri, 03/31/2006 - 12:54
I'd recommend adding the user to ACS as well as a local login. Remember, the ACS user id needs a high priv. level.
