Warning message
How to replace failed supervisor module IV on Cisco WS-C4506
Mar 28th, 2006
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5S-M), Version 12.2(25)EWA5. Cisco has RMA a new supervisor module. Please advise what are the steps to replace a failed sup mod
Prashanth Krishnappa Tue, 03/28/2006 - 07:28
  • Cisco Employee,
If you have compact flash card, back up the configs and IOS to the flash card. Swap out the Supervisor, use the IOS and config on the compact flash card to boot the new Supervisor.
PS: Remember to rate useful posts.
shaunjabrook Tue, 03/28/2006 - 08:09
To be clear on my side - as i have never replaced a failed sup module before - i would take the following steps - i do have about 122 mb free on slot0:
copy bootflash: slot0:
cat4000-i5s-mz.122-25.EWA5.bin
running-config
Then - I should be able to hotswap the failed sup module with the new one.
copy slot0: bootflash:
running-config
Verify
Please advice - thanks
