Warning message
IP communicator background list CME
Mar 29th, 2006
I wonder if somebody succeeded to configure a background list on the IP Communicator running on CME 4.0?
I followed the steps descibed in this document: http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a008062495a.shtml , but that didn't work.
I used the following List.XML script:
<CiscoIPPhoneImageList>
<ImageItem Image="tftp:desktops/320x212x12/TN-Fountain.png"
URL="tftp:Desktops/320x212x12/Fountain.png" />
<ImageItem Image="tftp:desktops/320x212x12/TN-MorroRock.png"
URL="tftp:Desktops/320x212x12/MorroRock.png" />
</CiscoIPPhoneImageList>
The images and List.xml are placed in Flash:Desktops/320x212x12.
The TFTP-server is enabled.
When I do a debug tftp event and packet I get the following output:
008178: Mar 29 12:45:34.755: TFTP: Server request for port 3298, socket_id 0x486
4168C for process 212
008179: Mar 29 12:45:34.755: TFTP: read request from host 10.13.10.56(3298) via
FastEthernet0/1.1
008180: Mar 29 12:45:34.755: TFTP: Looking for Desktops\320x212x12\List.xml
008181: Mar 29 12:45:34.755: TFTP: Sending error 1 No such file
CME tries to find the List.xml file in the Desktops\320x212x12 directory which doesn't exist on the CME. It should find it's file in this directory: Desktops/320x212x12.
Does anyone know how to overrule this? I was thinking of changing the default List.xml file, but I don't know where it is.
Overall Rating: 4.5 (2 ratings)
mchin345 Tue, 04/04/2006 - 08:53
  • Silver, 250 points or more
follow this procedure to upgrade the background images.
1) Edit the List.xml file by hand according to:
http://www.cisco.com/en/US/partner/products/hw/phones/ps379/products_administration_guide_chapter09186a00801d66b9.html#wp1089242
2) Upload the List.xml file to flash
3) Add to CCME:
tftp-server flash:List.xml alias Desktops/320x212x12/List.xml
4) Load the png files into flash and enter a tftp-server command toshare them as well.
aapedraza Thu, 05/25/2006 - 15:50
I have the same problem. On our 7970 phones the list works ok but not on the IP communicator. A minor inconvenience to us but it would be nice to have it work properly.
The workaround would be to use the following command:
Tftp-server flash:Desktops/320x212x12/List.xml alias Desktops\320x212x12\List.xml
However, IOS interprets \xxx (where xxx are digits 0 to 7) as an octal representation of ASCII – hence converts the \320 to a P resulting in the following being added to the running config:
Tftp-server flash:Desktops/320x212x12/List.xml alias DesktopsPx212x12\List.xml
The work around is to use the following command:
Tftp-server flash:Desktops/320x212x12/List.xml alias Desktops\134320x212x12\List.xml
This will work okay, until the router is reloaded, at which time the \320 will again be converted to a P.
An IOS defect has been filed but is not yet fixed. See CSCsd87810.
