Hot Standby with AP1240AG
Mar 29th, 2006
I have to configure an AP1242AG to working in a Hot Standby mode. The monitored AP is also an AP1242. However I am not using the Radio A interface so I disabled it but when the monitoring AP check the monitored AP, it detects the Radio A is down and so becomes active. Is it posssible to disable the monitoring of the Radio A ?
Rob Huffman Thu, 03/30/2006 - 06:32
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Georges,
Just a guess here, but perhaps you have the mac-address of the A radio entered on the Hot Standby? Check this out:
Access points using Cisco IOS software can be configured to support Hot Standby mode using the 2.4-GHz and 5-GHz radio interfaces.
Note If your access point supports only one radio interface, provide the MAC address for that interface only.
iapp standby mac-address
Puts the access point into standby mode and specifies the MAC address of radio on the monitored access point.
Note When you configure a 1200 Series access point with two radios to monitor a 1200 Series access point with two radios, you must enter the MAC addresses of both the monitored 2.4-GHz and 5-GHz radios. Enter the 2.4-GHz radio MAC address first, followed by the 5-GHz radio MAC address
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_guide_chapter09186a00804e7cf6.html#wp1037487
Hope this helps!
Rob
Please remember to rate helpful posts.......
georgesmaes Mon, 04/03/2006 - 09:36
Hi Rob,
Thank you for answering me.
Unfortunately, we must fill two mac adresses (one for the Radio G and one for the radio A) into the iapp standby "mac-address" command.
Georges.
Rob Huffman Mon, 04/03/2006 - 09:59
  • Hall of Fame,
    Founding Member
Hi Georges,
No worries! In your first post you mentioned that you are not using the A radio. I think that you should delete the mac assigned to the A radio and the Hot standby will work properly. It is monotoring the A radio because of the iapp stadby mac-address that you are assigning to the A radio.Just assign the mac for the G radio.
Boy that sounds confusing!
Hope this helps!
Rob
Please remember to rate helpful posts..............
georgesmaes Tue, 04/04/2006 - 01:00
Hi Rob,
In the monitored AP, the Radio A is shutdown.
In the monitoring AP, the Radio A is shutdown too.
On the monitoring AP, when I type the command: iapp standby @MAC_Radio_G_of_monitored_AP then the system answers me: incomplete command because it is waiting for the second Mac address.
If you think I am wrong, can you send me the command you think good.
Thanks a lot,
Georges.
Rob Huffman Wed, 04/05/2006 - 06:46
  • Hall of Fame,
    Founding Member
Hi Georges,
Sorry for the delay in getting back to you. I have read a number of documents on this subject since my last post and have come to see that there are some differences depending on which doc you read.Here is the example:
Note: If your access point supports only one radio interface, provide the MAC address for that interface only.
From this older doc:
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/tool3ios/mt_c2.htm#wp1036865
Note When you configure a 1200 Series access point with two radios to monitor a 1200 Series access point with two radios, you must enter the MAC addresses of both the monitored 2.4-GHz and 5-GHz radios. Enter the 2.4-GHz radio MAC address first, followed by the 5-GHz radio MAC address.
From this newer doc for 12.3(7)JA:
http://www.cisco.com/en/US/products/ps5861/products_configuration_guide_chapter09186a00804ed72a.html#wp1055446
I think I would go with the newer doc. Can you try entering the macs for both A and G radios, enabling the A radios but only setting the Data rates for the G radio. Maybe this would work. I'm at a loss for anything beyond this, and the documentation has left me with more questions than answers.
Hope this helps! Let me know how you make out.
Thanks Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
