Warning message
WebVPN Authentication
Mar 29th, 2006
I successed to let remote access users to be authenticated using ACS
(which use windows database)\.
but this did not work with WebVPN
it's only successed with Internal database.
morgsizun Mon, 04/03/2006 - 04:14
I suppose you use a vpn3000.
I think you should add your server for the group using webvpn under:
configuration | user management | groups
select your group and add an authentication server.
regards.
colomacrespi Tue, 04/04/2006 - 03:21
You don´t need to add an authentication server to the WebVPN Group. As it is explained in the configuration guide, the webvpn feature uses the global authentication parameters.
Anyway... I´m looking for the same thing...Were you able to find sort of solution to this?
morgsizun Wed, 04/05/2006 - 04:46
I agree with you but in this guide , it's explained that the first active server, independent of type, is used for authentication and authorization of WebVPN sessions.
So i tink that if the internal database is in first position in your authentication server list , the request isn't forwarded to next servers.
Regards.
w_basheer Thu, 04/06/2006 - 22:28
I successed to do this :
Authentication using ACS (Active Director)
I added a link URL point to http server.
Citrix BUT when i tried to open any application it gives me error stating that protocol error
p-weir Thu, 04/06/2006 - 06:02
Check under Configuration>System>Servers>Authentication that your RADIUS server is defined and at the top of the server list. Using the TEST option is very useful also.
Cheers, pete
w_basheer Thu, 04/06/2006 - 22:27
