Warning message
PBR ACL configuration to PBR certain hosts
Mar 29th, 2006
I have a route-map setup on a port to route only internet traffic to the next-hop. I would like to be able to route-map one of the ip's on the network that is being routed to a different next-hop. Here is my config:
ip access-list extended inet
deny ip any 192.168.0.0 0.255.255.255 (this is the network accessing the internet)
deny ip any 10.50.1.0 0.255.255.255 (this is the network on my switches)
deny ip any 10.51.3.0 0.255.255.255 (this is the network with different gateways to the internet)
permit ip any any
route-map dsl01 permit 10
match ip address inet
set ip next-hop 10.51.3.2
So the route-map is assigned to port 5 on the switch and it routes internet traffic to 10.51.3.2. But I would like to be able to route just machine 192.168.0.1 to a different hop (10.51.3.3). Can this be done in the route-map or acl?
Dan.
Overall Rating: 5 (2 ratings)
pkhatri Wed, 03/29/2006 - 14:40
  • Purple, 4500 points or more
Dan,
Try this:
ip access-list extended list1
permit ip host 192.168.0.1 any
permit ip any any
route-map dsl01 permit 5
match ip address list
set ip next-hop 10.51.3.3
Hope that helps - pls rate the post if it does.
Paresh
vladrac-ccna Wed, 03/29/2006 - 17:10
  • Silver, 250 points or more
That should work fine!
just dont forget the list1 ;)
Vlad
pkhatri Wed, 03/29/2006 - 17:13
Damn.. gotta learn to type. Thanks Vlad.
Here's the corrected config:
permit ip any any
match ip address list1
Paresh
