Switch Startup Problem
Mar 29th, 2006
AOA,
I have 2950 switch, whenever i start to configure it through console, it show me IOS bootup upto this screen, then switch Hange, what is the soloution of this problem,
### Message Display when boot ####
Press RETURN to get started!
00:00:15: POST: Loop back Test Failed on GigabitEthernet0/1. State:Disabled
00:00:15: POST: Loop back Test Failed on GigabitEthernet0/2. State:Disabled
00:00:15: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
000004: *Mar 1 05:00:18: %SYS-5-CONFIG_I: Configured from memory by console
000005: *Mar 1 05:00:19: %SYS-5-RESTART: System restarted --
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(19)EA1c, RELEASE SOFTWARE
(fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 02-Feb-04 23:29 by yenanh
Overall Rating: 4.5 (2 ratings)
ankurbhasin Wed, 03/29/2006 - 20:53
  • Red, 2250 points or more
Hi Mansoor,
Its hardware failure. From the message you will see its saying
"POST: Loop back Test Failed on GigabitEthernet0/1. "
which means post is failing the lopback test which is a hardware failure. POST is power on self test which when any device is powered on it will test all the hardare components.
So you have to get your part replaced.
HTH, if yes please rate the post.
Ankur
mansoor_nawaz78 Wed, 03/29/2006 - 21:01
Thank You for reply,
Can u please tell me the exact Hardware IC Or Component which i replace to correct it.
Thank You.
ankurbhasin Wed, 03/29/2006 - 21:05
Hi Mansoor,
2950 is not a modular switch and is just a one single box you cannot replace single seperate components and very sorry to say you have to replace the whole box.
Ankur
ankurbhasin Wed, 03/29/2006 - 21:15
Hi Mansoor,
Yes its not repsirable. Only thing you can try is take it to rommon when it is just booting up and do xmodem procedure.
But no gurantee it will start working and 99.99% or 100% it will display the same result so you have to get this replaced.
Try this link only .0000000000000001% chance it start working
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Ankur
mansoor_nawaz78 Wed, 03/29/2006 - 21:22
Ok thank You,
I have done it alraedy, accoding u ur 99.99% gurantee it was not proof helpfull for me.
Thank You
ankurbhasin Wed, 03/29/2006 - 21:28
Then go ahead and get it replaced
Ankur
mansoor_nawaz78 Wed, 03/29/2006 - 21:34
Ok, Can u tell me one thing more can i use it as a hub or physical layer device,
ankurbhasin Wed, 03/29/2006 - 21:38
Hi Mansoor,
Its a bad hardware so it will not work. Physical interface are failing the post test.
Ankur
