Warning message
Cable to connect to LocalDirector console port
Mar 29th, 2006
  • Silver, 250 points or more
my question is about getting access to the LocalDirector 430 through the console port: I thought it was just a regular rollover cable (with pins 1 through 8 reversed), but for some reason, that doesn´t seem to work. I know that there is a Cisco console kit for the LocalDirector, but does anybody know what the difference, if any, is between that console kit and a regular RJ-45 rollover cable ?
Thanks in advance for your help.
Nethelper
beth-martin Tue, 04/04/2006 - 12:20
  • Bronze, 100 points or more
Console cable and the rollover cable are one and the same. Any device with a console port should work with the roll over cable.
