Measuring ERL via 7900 Phone (show call active voice)
Mar 30th, 2006
  • Bronze, 100 points or more
Via the Tone softkey I called my cell phone and generated a 1004 Hz tone at -15 dB, then did a show call active voice.
Since the ERLLevel=30, I shouldn't have to adjust input gain/out attenutation. One person in our office states she has 2-3 calls a day where she hears herself. No other complaints out of 30 phones. No headset, CCM 4.1(3)SR3 with load P00307020400, H323 PRI Gateway (no analog).
JAX-3845#show call active voice
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 1
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
GENERIC:
SetupTime=315354050 ms
Index=1
PeerAddress=1024
PeerSubAddress=
PeerId=4000
PeerIfIndex=114
LogicalIfIndex=0
ConnectTime=315363060 ms
CallDuration=00:02:21 sec
CallState=4
CallOrigin=2
ChargedUnits=0
InfoType=speech
TransmitPackets=7374
TransmitBytes=1179840
ReceivePackets=7371
ReceiveBytes=1179360
VOIP:
ConnectionId[0x80E0515D 0xF3DDB11D 0xA000000 0xA0B0A5A]
IncomingConnectionId[0x80E0515D 0xF3DDB11D 0xA000000 0xA0B0A5A]
CallID=8333
RemoteIPAddress=10.11.10.12
RemoteUDPPort=25456
RemoteSignallingIPAddress=10.11.10.12
RemoteSignallingPort=60630
RemoteMediaIPAddress=10.11.10.90
RemoteMediaPort=25456
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=h245-alphanumeric
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=TRUE
H245 Tunneling=FALSE
SessionProtocol=cisco
ProtocolCallId=
SessionTarget=
OnTimeRvPlayout=145930
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=65 ms
LoWaterPlayoutDelay=60 ms
TxPakNumber=7302
TxSignalPak=0
TxComfortNoisePak=0
TxDuration=146045
TxVoiceDuration=146045
RxPakNumber=7299
RxSignalPak=0
RxDuration=0
TxVoiceDuration=145975
VoiceRxDuration=145930
RxOutOfSeq=0
RxLatePak=0
RxEarlyPak=0
PlayDelayCurrent=60
PlayDelayMin=60
PlayDelayMax=65
PlayDelayClockOffset=-804758489
PlayDelayJitter=0
PlayErrPredictive=0
PlayErrInterpolative=0
PlayErrSilence=0
PlayErrBufferOverFlow=5
PlayErrRetroactive=0
PlayErrTalkspurt=0
OutSignalLevel=-15
InSignalLevel=-74
LevelTxPowerMean=0
LevelRxPowerMean=-745
LevelBgNoise=0
ERLLevel=30
ACOMLevel=58
ErrRxDrop=0
ErrTxDrop=0
ErrTxControl=0
ErrRxControl=0
ReceiveDelay=60 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
SRTP = off
VAD = disabled
CoderTypeRate=g711ulaw
CodecBytes=160
Media Setting=flow-through
CallerName=Jonathan Nawab
CallerIDBlocked=False
OriginalCallingNumber=1024
OriginalCallingOctet=0x21
OriginalCalledNumber=93383245
OriginalCalledOctet=0xA0
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0xFF
TranslatedCallingNumber=1024
TranslatedCallingOctet=0x21
TranslatedCalledNumber=93383245
TranslatedCalledOctet=0xA0
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0xFF
GwReceivedCalledNumber=93383245
GwReceivedCalledOctet3=0xA0
GwReceivedCallingNumber=1024
GwReceivedCallingOctet3=0x21
GwReceivedCallingOctet3a=0x81
MediaInactiveDetected=no
MediaInactiveTimestamp=
MediaControlReceived=
Username=
GENERIC:
SetupTime=315354130 ms
Index=1
PeerAddress=93383245
PeerSubAddress=
PeerId=77
PeerIfIndex=126
LogicalIfIndex=61
CallDuration=00:02:26 sec
CallState=4
CallOrigin=1
ChargedUnits=0
InfoType=speech
TransmitPackets=7621
TransmitBytes=1280328
ReceivePackets=7624
ReceiveBytes=1219840
TELE:
ConnectionId=[0x80E0515D 0xF3DDB11D 0xA000000 0xA0B0A5A]
IncomingConnectionId=[0x80E0515D 0xF3DDB11D 0xA000000 0xA0B0A5A]
CallID=8334
TxDuration=152475 ms
VoiceTxDuration=152475 ms
FaxTxDuration=0 ms
NoiseLevel=-73
ACOMLevel=58
OutSignalLevel=-15
InSignalLevel=-74
InfoActivity=1
ERLLevel=30
EchoCancellerMaxReflector=46
SessionTarget=
ImgPages=0
Total call-legs: 2
Overall Rating: 5 (1 ratings)
Chris Deren Thu, 03/30/2006 - 06:38
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Actually in your example the ERLlevel is 59 dB, you calculate the ERLlevel with the following formula
ERLlevel=OutSignalLevel-InSignalLevel = -15- -74=59. If it is only happening occasionally, and as you probably know echo comes from the analog side, perhaps it is the remote side issue.
Chris
francis.labelle... Thu, 03/30/2006 - 19:45
I got the same problem, look at the bug CSCsd54344.
And then ask to TAC to send you the dspware for dsp 7.3.0.
That's fix my problem.
Another thing, if you are looking at the jitter delay in a CDR report, you will also see the you have a weird jitter value, don't worry, look at bug CSCsd44903.
P.S. I'm using a 2811 router with a PRI in MGCP.
