Warning message
amit-singh Thu, 03/30/2006 - 06:03
  • Blue, 1500 points or more
Do you know the SNMP community string of the switch if configured, then you can use the SNMP based discovery on the network and get the IP of that switch.
If not then the easiest way is to console into the switch and get the info. If you have some old config saved with you, you can check in that also.
HTH, Pls rate if it does.
-amit singh
mohamed-khadr Fri, 03/31/2006 - 10:08
Amit, Ok, Got it. Used SNMP discovery & got it.
Thx a lot
mohAmed
