AC transfer to Voicemail failed, CM 4.1.3
Mar 30th, 2006
I have CM 4.1.3sr3 and my Attendant Consoles fail to transfer to voicemail. I am running Unity 4.0.5. Does this work for anyone else? The Voicemail profile is set like all other phones. The lines can hit the messages button and go to the VM pilot number no problem. I looked at the acclient.txt file I see the following message "ERROR ACClientTelephonyMgr.transferToVM(): Pilot for[4241] is null". It's like the AC doesn't know what the VM pilot point is. I even tried putting in the Voicemailprofiles.xml file with no luck. Any ideas or suggestions would be greatly appreciated.
gogasca Sun, 04/02/2006 - 22:32
  • Green, 3000 points or more
DUP
Please check this and let me know
CSCed71318 Details:
Symptom:
Transfer to voicemail feature fail with error "Fail to transfer to voicemail".
Condition:
Failure occur if the destination phone's Voice Mail Profile is set to NONE under its line configuration.
This configuration will take the default system voicemail profile but transfer to voicemail feature will fail from AC client application.
However, manual transfer to voicemail using the hardware phone work fine.
