Warning message
FTP with SSL cert on ACNS via WCCP
Mar 30th, 2006
I have a client using an SSL cert to connect to an ftp server. The user is being redirected to a CE-511 via WCCP v2 but the FTP connection does not work. If I bypass the user (in my wccp acl) it works fine - following a default route to my PIX.
Any info, good or bad will be greatly appreciated.
- Matt
b.speltz Wed, 04/05/2006 - 07:46
  • Bronze, 100 points or more
What is the software version running on the CE-511. Did you try upgrading to the latest version of the firmware. This should solve the issue.
