what is the size of ip header?and frame header
Answered Question
Mar 31st, 2006
the mtu are all the same,right?but i forget the size of the ip header and frame header
Correct Answer by pkhatri about 11 years 4 months ago
The MTU is actually a reference to the size of the largest network-layer datagram that can be supported by a particular link.
The IP header is usually 20 bytes but can be up to 60 bytes when non-default Options are included.
Hope that helps - pls rate the post if it does.
Paresh
Overall Rating: 5 (1 ratings)
Correct Answer
pkhatri Fri, 03/31/2006 - 01:35
  • Purple, 4500 points or more
Paresh
