Routing Issue between router and Access Server
Mar 31st, 2006
We have a Lucent MAX TNT access server, having TAOS version 9.0.9. I
have configured
the default route so that all dialup user traffic is diverted towards
cisco 2611 series router but this
only happens with the IP subnets configured on MAX TNT and cisco router
ethernet interfaces.
We need a solution in which dailup users on MAX TNT with IPs from any network can
be routed towards the cisco router in order to reach the internet cloud accross the Router.
Richard Burts Fri, 03/31/2006 - 06:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Muhammad
Your message states that you have configured the access server with a default route pointing to the 2611 router. But it does not say whether you have configured a route on the 2611 pointing to the access server for the address range used by the dial pool which the access server uses to assign addresses to dial up users. I suspect this is your problem. I believe that the 2611 needs a route to that address space and that the 2611 needs to advertise that address range if there are any other routers in your network.
Rick
