Warning message
ssh login on cat4506 switch
Mar 31st, 2006
HI All,
I have a 4506 catalyst switch connected in LAN.I have disable the local user telnet but ssh login has to be enabled for some particular LAN users.
I tried by creating a permit list and downloaded a software name "Putty".
Is there anybody who can help me on this right from the scratch.
Overall Rating: 3 (1 ratings)
imranmohd Sat, 04/01/2006 - 01:28
Hi Bajpai,
Thanks for reply.But the ios in the switch is cat-ios.Would appreciate if u can send some more URL.Even i am trying to find out the informations on net.
Also how do i configure a ssh client.I have a software (Putty.exe) installed on client mahine.
Thanks & Regards
CSCO10662744_2 Mon, 04/03/2006 - 05:33
In my opinion, Cisco should make SSH available on all their devices w/o the need of obtaining an IOS w/ crypto capability.
Everyone knows telnet is insecure, and yet we're stuck configuring our switches through telnet due to the price factor.
imranmohd Tue, 04/04/2006 - 03:16
Hi Prem
Everything related to ip permit is acceptable byswitch But it is not supporting "crypto key rsa... command.
Can you put some light on this.
spremkumar Tue, 04/04/2006 - 04:01
  • Red, 2250 points or more
Hi Imran
you need to have the correct OS code for Catalyst 4000 Supervisor with SSH support,also as mentioned in the S/W compatiblity page you should have atleast K9 images as of 6.1..
The latest crypto code available is cat4000-k9.7-6-17.bin when compared to the normal code of cat4000-k8.7-6-17.bin..
regds
