Internet Sharing on broadband
mohit.saraswat
Hi!
I want to share the internet connection (broadband) of my host at the other computers of the LAN. I have tried using the proxy and broad band sharing at other clients and looking for the IP automatically at the other clients.
Kindly guide me in the problem stated above ASAp.
Bye.
M.SARASWAT
HCL INFOSYSTEMS LTD.
Patrick Laidlaw
Level 4
Level 4
If you have a broadband connection go pick up a Linksys router or PIX or some broadband router. Using your own PC is a pain for internet connection sharing.
Patrick
Hi!
Thanks for the solution but I wanted to share the Internet on to the LAN via wireless infrastructure and also wanted to maintain the same through RIM.
Can u help me in that.
Thanks in advance
M. SARASWAT
One more option which i would like to suggest is to connect your WAN(broadband) link on the wan port of any of the wireless compliant routers which can also be made to support your wireless LAN infrastructure..
you can choose up from any of these models (which belongs to 800 series routers).
851W
857W
871W
876W
877W
Other hardware compatabilities and support do refer this link..
http://cisco.com/en/US/products/hw/routers/ps380/prod_models_comparison.html
regds
