Warning message
vpn problem using NAT overloaded
Apr 1st, 2006
my customer having few vpn clients.
previously they have public IPs.
Now we assigned private addresses to them and configured overloaded NAT on router.
In this case only first vpn client working, remaining are not working.
If we use static NAT for each client, every thing is working
My question is: does vpn work when nat overload enabled?
if yes how to configure that.
skrao
m.sir Sun, 04/02/2006 - 08:51
  • Gold, 750 points or more
I guess you mean Cisco VPN client installed on PC (not Router like VPN client)
In Client configuration select connection entry - click modify - than select Transport - there check Enable transparent tunneling and IPsec over UDP
M.
