ASA5510 Issue First Part
Apr 2nd, 2006
Hi there. I'm trying to configure an ASA5510 with no luck.
My network is very simple. Computers on the inside with a single router connected to the internet. Use NAT to protect inside addresses and allows access to cetain machines with static addresses.
Here is my config file. Can someone help me to see what I'm mising. I can ping the inside interface and the gateway but nothing outside. Traffic will not flow out or in.
Result of the command: "show running-config"
multicast-routing
names
name 1.0.0.153 charlies
name 1.0.0.152 exme01
name 1.0.0.151 webserver
name 1.0.0.150 server
interface Ethernet0/0
nameif outside
security-level 0
ip address 207.xxx.xxx.254 255.255.255.240
interface Ethernet0/1
nameif inside
security-level 100
ip address 1.0.0.102 255.0.0.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxxxxxxxx encrypted
boot config disk0:/asa711
ftp mode passive
dns domain-lookup outside
dns name-server 64.xx.xxx.xx
object-group network MYSERVERS
network-object webserver 255.255.255.255
network-object server 255.255.255.255
network-object exme01 255.255.255.255
network-object charlies 255.255.255.255
object-group service WEBSERVICES tcp
port-object eq www
port-object eq https
object-group service EMAILSERVICES tcp
port-object eq pop3
port-object eq smtp
port-object eq chargen
object-group service VPNSERVICES tcp
port-object eq pptp
