Warning message
does 7204VXR support redundant NPE
Answered Question
Apr 2nd, 2006
hi,
what i know is 7204VXR will not support supervisor engines. It will support only NPE.
I am using only one chassis, so I want provide redundancy on 7204VXR. Does it support?
skrao
Correct Answer by pkhatri about 11 years 4 months ago
The only redundancy you get with a 7204VXR is redundant power supplies - you cannot install redundant NPEs/
Hope that helps - pls rate the post if it does.
Paresh
Overall Rating: 5 (1 ratings)
Correct Answer
pkhatri Sun, 04/02/2006 - 22:54
  • Purple, 4500 points or more
Paresh
